Missing files?
I have an icon named tmi-favicon.ico in my dropbox folder, where it has been for several days.
Global search key is set to ,
,tmi.ico returns nothing, and I don’t see the file if i search ico or .ico, either… Only an exact filename match returns the item. I’ve seen similar issues with other files. Is there another format I should be using here? Thanks again.
Sounds very weird. Does this happen to all the files or just some of them in your Dropbox folder? Can you search files in other folders?
P.S. It should be ,tmi .icon (with a space in the middle) unless you turn on fuzzy match in Listary Options - General.
