Listary with Dopus and Clipmate
Listary 4.0.1.1180 plus Directory Opus 10.5.0.6 and Clipmate 7.3.14 build 223.
If the option to Enable local hot keys when Listary toolbar is hidden is activated, then attempts to capture a selected file/folder name from within DOpus using Ctrl-Shift-C fail. The Clipmate error message reads…
The Windows Clipboard has data which Clipmate did not capture. The clipboard data may be invalid, or it may have been filtered by the Application Profile. See the setting for [DOPUS].
With the Enable local hot keys when Listary toolbar is hidden option deactivated, the DOpus file name capture works as expected.
I don’t know if this is a bug or working as designed?
Regards, AB
I’m sorry that Ctrl-Shift-C doesn’t support DOpus yet. It’ll be added soon.
