Listary doesn't work with Dopus in my system
I have the last version of Listary and it doesn’t work with dopus, although it works with other managers. I must say that I use a portable (pen) installation of Dopus and the Portable version of Listary and a non administration account. Is this the reason?
Please make sure you’re using the latest beta version of DOpus (10.5.0.6) http://resource.dopus.com/viewtopic.php?f=1&t=19071
OK, I’m using the previous one.
Now it’s working after upgrade but there is an issue I don’t understand: I have a folder with mostly LNK files where searches take a long time and end with no results with listary endlessly searching without results.
Sorry I don’t get it. Do you mean Listary missed some search results?
Listary gives no results, i.e. if for example I have a file "Internet explorer.lnk " and I write “Internet” it doesn’t find the file.
This is really weird and I have no clue why it’s happening. Could you please upload a screenshot?
How do I upload the screenshot?
Upload it to http://imgur.com/ and paste the url here.
You can also send the screenshot to support@listary.com
Here it is
http://imgur.com/ttjjHHB
Thanks for the screenshot. I’ll look into it.
The commands “copy paths etc. to clipboard” don’t work on my system (I’m using Dopus 10.5.1.0). Any idea how to fix this?
@dr_andus
DOpus has its own clipboard commands (e.g. Ctrl+Shift+C to copy full paths).
