Listary and total commander 8.0 RC2, with a lot of problems
Total commander 8.0 RC2, WIN + O to open the file, only open the folder containing the file, but 7.57a use WIN + O normal
Hello duola,
Thank you very much for your feedback. I’ll look into this issue.
Like this
I use windows7 64bit systems and total commander (64bit) 8.0 RC2.
Hello duola,
Thank you very much for the screencast. I’ll work on this bug immediately after finishing Listary 4.
