Is there a way to artificially move top results?
Is there any way to put results that are want to be showed up on top or is selecting the option until it goes to the top is the only way?
The new Listary 5 implements keyword based history. For example, if you type “li” and select “listary.exe” from the results, “listary.exe” will be automatically shown on top the next time you type “li”.
Great to hear. When will Listary 5 be released? :slight_smile:
No comment :wink:
