Listary Pro 5.00.2410
Windows 10 x64
In old version (Listary 4?), Quick Switch is working smoothly to me.
For example:
- I have an open file dialog, browsing C:\A
- I open a file explorer and go to C:\B
- Then, switch to the open file dialog, and it automatically goes to C:\B.
However under Listary 5, it doesn’t work as before.
Still take the same scenario as example.
In step 3, after I switch back to the open file dialog, it’s still browsing C:\A, not C:\B as I want.
I confirmed Options - General - Quick Switch (Open current folder in file dialog when switch from a file manager) is toggled on. I tried turning it off and on again but that doesn’t help.
Is there any change to use Quick Switch since version 5?
