How can i enable Fuzzy Navigation in a project
listary pro version is 4.02.1360
Probably by just activating it in the Listary options in the general tab. Here you can set fuzzy navigation. It should be a general option that works for all types of searches.
i has already enable this option, it works well in normal mode
but, it cannot work in blow case:
i set a project named pj, and link to c:\workspace
search like this:
pj t.txt
cannot match c:\workspace\test.txt
pj t.txt should work even if you don’t enable fuzzy navigation because test.txt contains t.txt. It seems something is wrong here. Could you please try if pj test.txt and pj some_other_files work as expected?
case1:
pj s.t match test.txt
case2:
s.t match test.txt
it seems, fuzzy navigation cannot work in project search
Sorry I’m a little confused. I think you’re looking for Fuzzy Matching instead of Fuzzy Navigation.
sorry for my pool english
but, i also enable the Fuzzy Matching
why the Fuzzy Maching not work in the project
but work well out side the project
Sorry that Projects only supports keyword matching currently. I’ll add Fuzzy Matching support in the next version.
