Hotkey to jump to the next/previous section in 4.23.1728
The feature “You can now use Shift + Up/Down to jump to the next/previous section” is not work in the last version 4.23.1728.
I coulduse Shift+Up/Down to jump different section (Folder, or File, or Projet…) in Listary before.
But it seems be disabled in this version, shift+up/down will only perform multiple-file-selection in the explorer/files dialog.
Is there any other hotkeys (or settings) for JUMP TO PERVIOUS/NEXT SECTION ?
Thanks in advance.
Arsene
Thanks for your feedback. These two hotkeys seem to have been overwritten in the new version. I’ll add them back soon.
