Fuzzy Navigation disappeared?
I’ve installed the latest version (4.1.0.1446) and there’s no option to enable Fuzzy Navigation.
I thought it might be enabled now regardless of settings, but it doesn’t seem to work at all.
Is there any change in the new version to the way it works, or is it a bug?
Fuzzy Navigation has been removed. It’ll be replaced with something more powerful and easier to use very soon.
Thanks.
I assumed it’s something like that, seeing the question about the foldername search. :slight_smile:
