Folder entry can't be opend in xyplorer from desktop
Afther I open an folder entry in listary on desktop, It can only swith to xyplorer (my default file manager), but can’t open that folder
In the open dialog menu, “open the file selected in file manager”, “explore current folder”, “explore appliction folder” are also not work.
btw, “current opend folder” in the open dialog menu can’t only list current actived tab of xyplorer, not all. Is it designd?
both listry version 4.02.1360 and 4.01.1191 are be
xyplorer version is 12.80
Thank You!
In Default File Manager settings, try to fill Parameter with "%1" (including quotes).
