Flickering problem with Adobe Photoshop and Illustrator CS6
I recently upgraded to Adobe CS6 from CS5 and Listary is almost impossible to use after this.
It’s continuously flickering with CS6 programs but works just fine with CS5!
After searching I found this thread and it was marked resolved with the Listary 4 Beta.
http://discussions.listary.com/discussion/86/problem-with-photoshop-cs6/p1
But now I just installed the latest version 4.01.1175 and the problems is still there.
Is there any solution to it?
This bug was fixed and one update broke it again :frowning:
Next version will fix it.
Oh okay!
Could you tell when the next update is coming?
48 hours :slight_smile:
Great! Thanks :slight_smile:
Downloaded the updated version.
Thanks a lot for fixing it Channing :slight_smile:
