Feature Request: Options for Menu: Recent
It would be great if i had the opportunity to change the following options for Menu:Recent:
  1. Number of entrys for each List of Menu:Recent
  2. The order of the lists: I need the list for the global items much more often than the list for program spezific items.
    I never need the file list
    Currently, I often have to scroll down to show the global list, this is very cumbersome.
Thanks for your suggestions! In fact they have already been on my to-do list for a while, but the priority is relatively low.
Be able to change the size of the lists is very good, I + that.
Thanks for your feedback. I think it would be a good opportunity to set the priority of this to-do to the top :slight_smile:
