Double click not working in Win8.1?
Thanks for this wonderful work.
My probelm is that Double click not working in Win8.1
4.02.1360, working normal in win7.
However after upgrade to win8.1 and make a new listary installation, the double click menu disappears.
Tried set the run as administrator but still same.
Sorry for the inconvenience, but Listary’s double-clicking does support Windows 8.1. Is it possible that some other applications are interfering with Listary?
Make a few test in my PC:
If run listary using the windows scheduled task, double click not working.
Manual running listary from explorer, double click working.
I suggest you use the installer version and uncheck “Run as administrator” in Listary Options.
Woo, that works! Thanks Channing!
