Is there a way so that the results box does not show PATHs below the actual results?
Do you mean you only want to use Listary to search for applications?
I only want to see the items in the list I’m typing. I don’t want to see their path or any other information, Just the name that I can click on.
Search results without a path are almost useless.
How can you select what file to open if multiple matches are found ?
Because I’m already in the f…king directory or the search results that already contain the path.
Sorry that there is no plan to support it.
