Custom index folder
Can you add the possibility to specify a custom folder where to save the index ?
Currently I’ve set the Windows Search’s index path on a ramdisk partition, that is saved on disk (an SSD) at shutdown and automatically reloaded at boot. This make the searchs faster (the index is in ram), and avoids unnecessary writes on SSD at every index update.
It would be useful do the same thing with Listary. Can you add this option in settings?
Hi, Listary only accesses its index file during starting up and shutting down. When it’s running, only the index loaded into ram is used. So you don’t need to do this manually with Listary.
Oh well, in this case it’s even better than I was thinking. Thank you for your rapid response!
