Create Directory Opus plugin for deep integration?
Hi Channing, may I suggest you to consider create a Directory Opus plugin to make Listary even work better with this amazing file manager? It could be awesome just to make a global or by path search (like Everything) just in a lister and automatically export the results to a collection. Just think about it. Thanks.
PD. What file manager did you use?
I haven’t written a DOpus plugin before. I have to do some research first.
I use almost all popular file managers (I need to test Listary) :slight_smile:
