Command prompt
Is there any way to open a 64bits cmd or a cmda rather than always open a 32 bit version?
Thank you,
Hini
Windows redirects Listary to use the 32bit cmd automatically (and unexpectedly). I’m working on a solution.
I think it’s because listary is running as a 32bit process and the environment that’s “available” is the 32bits rather tan the 64bits
