Can't disable double click on empty space to display Listary menu in 4.0
Hello, Channing.
As the title says, I can not disable that option from the program. I use Q-Dir as my file manager of choice, and I have it set up so that I double-click an empty space to go up a level. The problem is that whenever I double click on an empty space, Listary menu appears. Even with this option turned off in all programs listed in Listary Options - By Window Type. I’ve tried with all versions of the 4.0 branch of Listary and all the same behavior happens. Right now I’m using version 3.51.858, which does not have this problem.
In case it is useful to know, I use the portable version of Listary. I also use the portable version of Q-Dir (x64) and my system is Windows 7 64-bit.
Best regards.
Thanks for reporting. It seems to be a bug. I’ll fix it in the next version.
Hello, Channing.
Today I installed the new version (4.01.1191) and the problem I described in my first post disappeared. Thank you very much, Channing!
Find-as-you-type is the only function that I use in Listary, and with this new versions (4.x) is faster than ever.
Keep up your good work!
Best regards.
