Can I look in 'Project' by default (rather than Path)?
I find that I’m using the “Projects” feature quite often (usually from the desktop). Listary seems to default by searching for “Path” matches (bottom of menu L menu). Once it doesn’t find a match it will, then, search for Project matches. Is there a way for me to have it search Project matches first?
There should be no need to do this manually. Your most used folders will rank higher than others.
The results will become more accurate after using Listary for some time.
Channing said:
hello, sorry for posting the similiar question just now.
however, often, i use PROJECT feature in any directory instead of the desktop.
when i need to jump to a project folder, i just type in my Dopus window, regardless where i am now.
in that case, i don’t think that the ranking database listary collects can still make it accurate.
