Bug of "open with"?
In the context menu, the “open with” does not work. Same problem with the “send to”
I’m sorry for the inconvenience.
This is a known issue. “Open with” and “Send to” work differently from standard menu entries. Currently this can’t be fixed.
是的,这个问题我也发现了,打开方式无效,发送到也无效。。也不知道是自己不会用。。还有,我还不太会用正则表达式和一些语法搜索功能,好像下个版本会有这些功能,希望到时候能提供中文版本的教程和示例。。。谢谢。
@baifengs
帮助及更新后的教程都会有的 :slight_smile:
