Add to favs using disk label?
Hi Channing, may I suggest you that please add support to add a favorite using the disk label?
Let me explain this for you. If I add to favorites an extractible disk (ex. pendrive) it will use the letter assigned to that disk at that moment, however that letter could and it will change sometimes, make it the shortcut useless, but if Listary create the shortcut using the disk label ( if available) the shortcut remains regardless of the letter. Hope you undertand me. Thanks for listening.
Thanks for your suggestion and I understand what you mean.
It may not be a good idea to use volume labels because they are not guaranteed to be unique. Instead, I suggest you assign static drive letters manually to the devices you use often.
