Action - Move to Current Folder does copy and not move the file
When I use the “Action - Move to Current Folder”, a window pops up asking me, if I really want to move the file. I tried this some times with different files and I always clicked yes, but the file is not moved but copied (= the file still exists in the old folder). Usually this is a bug, but as I’m very new to Listary there is maybe another solution for this, which I can’t find or which I have to edit in options? Listary is working on Win8/64bit
Thank you very much for reporting this bug. I just did some tests and can confirm that Listary may fail to remove the original file on some systems. I’m working on a fix now.
