2x Ctrl
I have realize that “Lookeen” (https://lookeen.com/index.html) use the same shortcut to open a search.
It is possible that user can change the double-Ctrl in Listary in a other double tapped key (for example 2x Alt)
I like to can use this function for both applications.
Andy
Thanks for the feedback. It has been added to the plan.
Awesome, thank you Channing!
I’ve been playing with the beta and really enjoying it. And while I really like the 2x Ctrl shortcut, I’ve found it interferes with too many of my programs and games.
I would love the option to manually change the key to something I use infrequently. e.g WinKey
I’ve disabled the Win-X Hotkeys/Start Menu activation on my system and replaced the WinKey comobinations with my own scripts. The Windows key makes for a superb additional modifier! :blush:
Thanks again for the awesome updates!
