When Listary Pro is running on a computer that uses X1 search software, and X1 is also running, when I do a double Ctrl press and bring up the search window, the window opens and then shifts over to the X1 search box in X1, totally bypassing all Listary functions. Is there a way to work around this (other than close X1, which would be a major inconvenience since I use it many times a day and that would also prevent its automatic background indexing from operating.
Thanks.
