Working with Listary and severally accounts
Hi Listary Team,
there are multiple accounts on my desktop using Listary 5 beta. If I do login in an other account Listary will not work but I’ll get an error message about wrong version installed. To avoid this problem I’ve to logoff from the first used account and login into the other one after this. It seems to me that Listary will run well on one account per time only.
But that’s not very usefull because I do sometimes need several account running side by side.
I’m sorry that currently Listary can’t support multiple instances running at the same time. To run Listary on your second account, you need to exit Listary on your first account (you don’t need to logout the account).
I’ll try to work on a fix for this. But it requires lots of fundamental changes, and may take some time.
