What does 'Set Keyword' do?
Where
Options -> Actions -> Set Keyword
Issue
Try to use this action on files and folders. Nothing happens after I set a keyword. Typing the keyword in Listary does not show the associated file or folder.
I can not find any help or doc on this topic. What does it do?
Action’s keyword is not for searching files or folders but for taking the associated action on the search result you select. That means you must first search and select the item you want to do something with, then input action keyword and press Enter to take the action.
  1. Please make sure your keyword contains at least 2 letters.
  2. Please upload a screenshot of Listary Options - Keywords which contains your keyword setting, and also a screenshot of Listary’s search results for your keyword. Thank you.
I understand and it is working now. Thanks for the reply
