I run XYplorer as the default Windows file manager and with the option to only allow one instance. Opening a folder switches to the running instance of XYplorer if there is one, or opens a new instance if it’s not already running, then moves to the folder requested to be opened. This works correctly if Listary requests a folder to be opened, IF XYplorer isn’t running OR XYplorer is already running at user level. However, if XYplorer is already running elevated to administrator level and Listary requests a folder, the running instance of XYplorer is switched to but XYplorer doesn’t move to the requested folder.
The Listary pop-up search box and list appears automatically when typing IF XYplorer is running elevated to administrator level, however, if XYplorer is running at user level, the search box and pop-up don’t appear when typing. The search box does appear in the correct position when [ctrl][ctrl] or [#][S] are pressed.
Any way to resolve either of these issues? Thanks
