Total Commander integration doesn't work
According to http://www.listary.com/total-commander-integration I’m supposed to press Win+O to switch to TC in an “Open file” dialog. Nothing happens, instead I just enter “O”. Then I found a post saying that Win+O was removed. But Quick Switch doesn’t work either. Pressing Ctrl+G does nothing.
For what it’s worth, I’m using TC 9.0a rc1 on Windows 10.
Win+O has been removed. Quick Switch works well with TC 9.0 in my tests.
Make sure you’re using the latest version of Listary 5.00.2410. Does Quick Switch work with Windows Explorer on your system? You can check this video to see how Quick Switch works: https://www.youtube.com/watch?v=9T9-OtRVeUw
