Hi, I just bought Listary because a user in the SpeedCommander forum mentioned it (and that the current beta version integrates into SpeedCommander).
My main question is: how I should set up Listary to use SC as its Default File Manager? I tried the path to SpeedCommander.exe in the first field, and “%1” in the second field, setting the dropdown to “Custom” - but I don’t think it’s working - if I select a Word document in SpeedCommander and then press Ctrl-O in the Word file open dialog, I just get an “error” sound.
Or what functionality should I be expecting when I’ve set that option? How can I test it?
I also tried Win-O (in the hope that it would work as outlined in “Total Commander integration”, but no luck either.
My other question: I’m looking for a manual or help file that lists all the commands and keystrokes etc. I should know, but I couldn’t find anything. Can you point me in the right direction?
Thanks,
Tim
