The add here to favorites in order to add the current directory to favorites, doesn’t work.
I’m using windows 7 - 64bit
When you use the hotkey in Explorer, you activate Listary outside of Explorer as a global application, so there is no current folder. Instead, you can:
- Press mouse middle button in Explorer to bring up the popup menu.
- Don’t use a hotkey. Just type directly in Explorer to activate Listary.
You are right, it works.
