Search path! Listary beta 4.20.1487
###Download link
###How to search in path
Add a trailing \ to a keyword to indicate that it’s part of the path.
Example: If you want to search notepad.exe in Windows folder, you can type win\note or win\ note or note win\.
###Change log 4.20.1487
  • New: Search path
  • New: No more flickers when showing search results
  • Fixed: Minor bug fixes
Hi
when I use the trailing to a keyword Listary doesn’t find any entry.
@jcmn
Could you please upload a screenshot?
Before that, the fact I’m working with a non-administrative account is a possible reason?
@jcmn
I don’t think so.
@Channing
I like the new launch apps feature but unfortunately batch files (.cmd, .bat) are launched with a wrong working directory.
Seems to work for me…
Channing said:
@jcmn
I don’t think so.
How can I upload an image?
@jcmn
Upload it to any image sharing service (like http://imgur.com/), and paste the url here.
You can also send the image to support@listary.com via email directly.
The link for the image is
http://imgur.com/xf0fPxJ
@jcmn
It seems that you’re not using the latest version… Make sure you’ve downloaded and updated Listary successfully.
@Channing:新春快乐了,今天上网,发现又更新了,呵呵。不错,就是感觉路径匹配还不够人性化或智能吧,不过我现也不追求什么了,够用了,像再优化拉,插件支持啦,我可以慢慢等了。
@Channing :发现个小问题,就是用路径匹配符的时候,匹配上的目录文字建议有个加红加粗等的区别。。这个是我从Everything上对比出来的。
Channing said:
@jcmn
You’re right I was using the previous version. But I could swear that I was quite sure to install the last version. Anyway problem solved.
1487版好像bug还在,,,搜索后,右建菜单(->),会闪消。。。
Hi Channing,
You may remember me.
I’ve been begging for an update that would make Listary work with Lucion’s Filecenter. Any chance you could look into it?
Thanks,
Andrei
@baifengs
这个会有的。
目前还没有收到其他报告。是Listary工具栏和搜索结果消失还是Listary崩溃?
@MincovLaw
Yes, I remember you. However I’m not able to implement FileCenter support :frowning:
Channing said:
@baifengs
这个会有的。
@Channing : (1)是搜索结果出来后,使用右方向键,即动作的时候,弹出的动作菜单我想使用打开文件夹,结果在80%的时候会闪一下就消失了。。尤其是在桌面状态下和其它程序激活的同时调用win+s搜索的时候。比如打开浏览器激活的状态下。(2)此外使用右方向键的时候,左方向键又不会返回到上一步了。(3)有时候把关键字删除或删除再切换,具体也不太记的了,会出现bug报告发送界面。
The trailing works here perfectly (i was the one requesting it)
And it’s a HUGE time saver! Thanks!!
It even works with multiple directories
