System Info:
- Windows 8.1 x64
- Listary Pro 5.00.2410 (in Chinese)
Reproduction Guide:
- Start Windows file manager, navigate to any folder that you have write permission.
- Launch listary searching bar, type name of an existing file which is not in current folder.
- Select the file in Listary’s drop down menu and press
ctrl+o
. - Select
Copy to current directory
Observed behavior:
Nothing happened. No file was copied to anywhere.
Expected behavior
The selected file should be copied to the current directory.
Other Info
It has been working until recently. Maybe it’s due to my recent installation of other applications? Let me know if you need any other info to solve this.
PS: I’m using Chinese version, so I don’t know if my translation is correct. And I think bug related posts should be put here. So that’s it.
