[Request] Menu commands for specific processes
It would be great if we could create custom menu commands that only show up when a specified process is the active process.
For example, creating a custom menu command “Open Todo-list” which launches Todo-List.txt
But it is only visible in the commands menu when notepad.exe is the active process (before Listary becomes the active process due to pressing the menu hotkey)
This way, we can create a lot of custom menu commands, which could be autohotkey scripts, batch files, or just context-sensitive commands in general, without overcrowding the commands menu globally.
Thanks for your suggestion. Personally I think this feature would not be used very often. I’ll record it, but may not add it in the near feature.
