Recommended way to work with Directory Opus Filter bar
#1
Directory Opus has a Filter Bar (to filter files) using * key.
With Listary * key pressed disable the Filter Bar.
Someone has a workaround to have Directory Opus Filter Bar and Listary working both?
Thanks
#2
Hello gabrielizalo,
Thank you for the post. Is there any way to disable the item in DOPus? I’ve heard it’s very configurable?
  • doesn’t do anything on my listary but I use the app bar mostly and not the filter bar.
hopefully channing can help out better
#3
I don’t want to disable Filter Bar… I want to enable.
DOpus Filter Bar appears pressing [*] key, but pressing that key appears Listary.
I want a workaorund soI cant use Filter bar but continuing using Listary inside DOpus.
Sorry. For not to be clear.
#4
I had this problem too, I’ll share my workaround, maybe you’ll find it intuitive as I do.
  1. In DOpus, go to Preferences, File Displays, FAYT and Filter Bar Keys.
  2. Change Default mode (no activation key required) to Filter
  3. In Listary Settings, General, change Prefix to disable find… to ` (tilde key). I find this useful as I don’t have to press shift+8 fifty times per day.
Now in Dopus, just press ` to disable Listary, then type to use the filter bar. This is second nature to me now.
There are many ways to achieve this; the critical step is using the disable key in Listary
#5
Yes, check Options - General - Prefix to disable FAYT. It should be helpful.
#6
Hey Palladios…
Godlyyy… Thanksss… My default “Prefix to disable find…” key is “!”.
I´ll keep it.
It works perfecttt!!!
Thanks a lot of!!!
#7
Thanks so much for this idea! It was driving me crazy within DOPUS. FWIW, I made a slight modification. As suggested, I changed the Disable prefix to ‘, but then I also changed the Filter Bar activation key to the same thing (’) instead of *. In this way, I can just hit the ’ key twice in rapid succession, and…voila! I have my Filter Bar. Much faster for me than hitting ’ and then shift to the asterisk key.
Love Listary…can’t imagine being without it.
