Problem with search folders in desktop
#1
Hi
When i search some folders on desktop then press Enter key nothing happened, even when press Ctrl+Enter keys the desktop folder open in file explorer
I use window 10 Pro
#2
I’ll check it.
Ctrl+Enter is the correct behavior because it opens the parent folder.
