sometimes the Listary toolbar is on top over all.
Is there anything I can do to stop it?
The toolbar is a topmost window. It’s very tricky to make it second-topmost. I’ll see what I can do.
Please don’t alter anything in the code concerning topmost so that others will have problems.
In preferences—app settings—Klik + to add your application—Toolbar Position you can set the offset per application. This way you can position the bar in a position you want it to be.Say under the list.
Wich application are you using?
That is correct!
You see the 5-5? There you can put a number to shift to left and further down the bottom. So if you put say -30 in the last 5 then it should drop 30 pixels down.
The
5
5
is for moving the bar to a certian position
The last 5 means 5 pixels from the bottom, so if you increase the number, it should go down quite a bit.
Just try some numbers and see what happen.
You should check from the bottom!
Try it, it should work.
I also have Notepad++ and check and report back.
EDIT: I just checked and I don’t have a search bar under the save as dialog in Notepad ++.
I’ll update to the latest version and report back.
EDIT2:
I just updated to version 7.5.1 64 bit and I don’t have a Listary searchbar under the save as dialog screen.
As you can see in the screenshot, there is no searchbar in Notepad++ 7.5.1.
the same with: C:\Windows\notepad.exe - no toolbar
Problem solved then?
No!
I just want the toolbar to be displayed at the same level as dialog boxes.
And it should be under the dialog box, not under the list.
I found out that mine is actually going up! Via windows 10 search and start notepad ++ will activate the Listary search bar!
Have a look at my screenshot:
It should never be uncoupled from the dialog box
Have a look at my other post. My list is going up.
I don’t have your problem.
