Listary can't start control panel items (*.cpl)
#1
As the subject says, Listary can’t start control panel items.
They are found with Listary but you can’t start them.
Explorer and other file managers are starting them without problems.
#2
Something is either wrong with your install or windows system.
Works fine in X64 windows 10 here
#3
Its Listary 5.00.2664 under Windows 10 x64, Creators Update.
Its definitely a Listary problem as all other tools and several file managers can start cpl files.
All other functions of Listary are ok, so its not an install problem.
I know what I’m doing and I’m also programming since many years.
#4
Same exact scenario here except I am running v2581. Where did you get v2664 from? Link me and i’ll test for u
Maybe create a portable Listary install and try again? Rebuild index?
How do you access control panel items? EDIT: That’s the discrepancy. I manually create shortcuts from control panel in a folder and have listary index them.
EDIT 2: got 2664. Control panel links work fine. Launching Ctrl panel works too. I don’t know where to get .cpl files to test out
#5
Your Windows has a lot of cpl files under C:\windows\system32*.cpl
Listary has no problems to find them all
#6
Thank you for reporting. This issue will be resolved in Listary 6.
#7
Sorry for late reply. Yes, i can confirm with this version it has problem.
Channing - is it possible to please create a beta area, beta list, beta notification - anything for us people who want to test out new features/fixes?
#8
I’ll make a post when Listary 6 beta is ready to release, and you can follow it to get email notifications for updates.
#9
Hi, where can I find latest beta 5.00.2664?
#10
You can download it here: http://www.listary.com/download/beta/ListaryBeta2664.exe
It’s only a bug fix version and contains no new features.
#11
Thanks, is there any chance to have the portable version?
M.
#12
Sorry there is no portable version for this beta.
#13
No problem, Thanks!
