####Download
####Change log 5.00.2406
- Improved: Improve search result sorting.
- Improved: Open toolbar in Explorer when pressing hotkey if find-as-you-type is disabled.
- Fixed: Listary can’t get current folder path from XYplorer when Live Filter Box is visible.
- Fixed: Currently Opened Folders doesn’t work in Total Commander 64.
####Change log 5.00.2381
- New: Now you can use spaces when searching for apps.
- New: Add EF Commander support.
- New: Show files when auto-expanding favorite folders in menus.
- Fixed: Listary is activated unexpectedly when using pinch-zoom on Synaptics touchpads (agaaaain).
