Hi Channing,
I love what you’ve done with Listary! Which major features are you working on in version 6, and how far along are you?
My only real complaint about Listary 5 is the lack of high-DPI scaling. The text looks blurry on my Surface Pro 4.
Oh–and I’ve got a suggestion. In 6, add a configurable action to attach whatever file is selected to a new Outlook email that can be addressed to whichever recipients are specified in the config. Note: I do this today with Listary 5, but it involved going to a bit of trouble to figure out how to create a custom action and what Outlook’s command-line switches are. Hopefully you can make this easier on the user in 6.
Also, I use Directory Opus. When I select a file in it, I’d like to be able to use Listary 6 to retrieve the selected file(s) and attach them to a new Outlook email. In 5, my custom action relies on Listary, itself, identifying the file I want to attach first. It would be so much better if, in addition to that, 6 could just grab the selected file(s) in dopus and pass them on to Listary’s custom action. Yes?
Out of curiosity, how many hours of work do you estimate a major release involves?
Good luck–and hurry!
Steve
