Insert a network path
How can I index a network path if it is not visible in network map? In Explorer the path is: \\GRP1$\Folder
Thank you
Unfortunately this is not supported at the moment. I’ll add it in future versions.
This is a terrible lack: I bought the paid version to index the network folders and now I find that it can’t to make this job. Please, please add the input field as soon as you can.
Thats not just adding a input field.
Network folders can not be indexed like the local NTFS based MFT.
There is at no place promissed to index network folders for the Pro version.
A tool which can do this is Everything.
These are the feature of the Pro version that mislead me in this context:
Index and search shared network folders
Index and search custom locations
It’ll be available in the next version.
Great news!
Thank you
