I want to be able to start a .bat file when I found it with Listary. But I want to start CMD first and then execute the bat-file in the opened CMD rather than just executing the bat file. This has some advantages:
- If the bat-file fails you can see what is going wrong. The CMD window will not close when the program exits
- You can easily restart the program (CTRL+C to exit the program then arrow up and enter)
I also would like to see that the CMD has the path of the bat file as working-directory.
Can this be done with Listary?
Thanks
