I want to suggest a little enhancement for the search including parts of the path.
The necessity to add a \ to the words that should be considered as parts of the path is cumbersome if you can’t remember exactly which words are part of the path and which are part of the filename itself.
Let me give an example …
The following file could show the timetable of one of my kids
BUT if I want to keep all the school related files from Peter in one folder this could just as well look like this
What I’m trying to say is…
… it depends on the situation and your personal preference how you organize your files whether ‘peter’ is part of the filename or part of the path.
But, when I want to quickly search for the schedule of Peter I don’t want to try different variations -> I just want to type [peter schedule]
Sorting …
The fact that words match either the file name or the path could be used for the ranking/sorting.
I would assume files where all words have a match in the file name should be ranked higher than those with matches in the path.
If there are users out there that prefer the current behavior => this could be an option.
I hope you like the idea.
Chris
