I met a strange problem of failing to inject into some unspecified processes, and after hard working I’ve found the reason: those processes’ file paths are quite special.
I’m explaining what I did to my computer caused the probelm;
- Says there’re 3 drivers: 40GB/NTFS, 60GB/NTFS, 100GB/NTFS.
- Then I use Disk Management of Windows to manage their mounting strategy.
- Step 1, assign the driver letter “
C
” to the first partition (the 40G one); - Step 2, assign the driver letter “
D
” to the third 100G one; - Step 3, mount the second 60G one into a path of
D:\Program Files
; - Step 4 (optionally), assign the driver letter “
E
” to the 60G one (here NOT delete theD:\Program Files
mount point).
And then, Listary works perfectly EXCEPT on those files under D:\Program Files
- if I copy
D:\Program Files\7-Zip
toC:\7-Zip
, then Listary works onC:\7-Zip\7zFM.exe
- if step 4 has been done, Listary works well on
E:\7-Zip\7zFM.exe
That’s all I’ve done and this problem affects both x32 and x64 executable files, so I consider it as a bug.
