I know that I can switch to the current folder in a file dialog simply pressing Ctrl+G.
But sometimes you have many opened folders and so you can: select the folder in windows explorer or go to Smart menu β Currently Opened Folders for quick access.
Is it possible to add a shortcut (I say, Ctrl+Maiusc+G) to rapidly show Currently Opened Folders in order to select one of them?
It would be an extension of Ctrl+G shortcut.
