for me currently the syncing (Quick Switch) between Explorer windows does not work anymore. It was working for sure previously. Any known problems here?
I’m on Windows 10, Build 15063.483.
Many thanks!
Many thanks!
Can you still type directly in Explorer to search?
No such problem here with Listery 5.00.2664 and your x64 Windows version.
Yes. Everything (I’m using) is working as before. Only the syncing disappeared.
I have 5.00.2581. Did a fresh install yesterday. Where did you get the more recent version?
I completely removed Listary and rebooted. Did a fresh install, and now it works again. No idea what went wrong.
But well, works now. Keep up the great work!
