Hi.
First of all, congratulations for the app.
Some free launchers allow “emoji search” by using plugins.
Can I do that with Listary?
Today I purchased Listary Pro and uninstalled other launchers.
Regards,
Hi.
Regards,
Do you mean search for a emoji using Listary and insert it into the cursor location of another app?
Just put the code at clipboard. See:
That should be simple once Listary supports extensions.
When?
I’m not sure about that, but extension support will definitely be added in a future version. The current priority is Listary 6.
OK.
Let’s wait!
Tks
