Disable double click / middle click on desktop?
I use Stardock fences, which allows you to hide icons either by middle clicking on the desktop or double left clicking on the desktop.
Sadly, Listary also uses these shortcuts to bring up the quick actions menu. Can I disable it? I’ve had a look through the settings and can’t seem to find it.
Hello Zax. Uncheck the box for “Desktop” as shown in the screenshot below.
Ah, must have missed that. Thanks!
I recommend that keep Desktop checked, and uncheck “Mouse double-click” & “Mouse middle-click” on the right panel instead.
