Love Listary and have used it for years. Recently, I discovered the Ctrl+Ctrl key to open is the same combination to open a small program WizKey (https://goo.gl/Oc0BXi). Would you consider making the Ctrl2 an option, such as Alt+Alt, or some other user created key combination?
Dennis Hays
