Control panel items
is there a setting in listary to be able to search settings/control panel shortcut? Is this a pro feature only because if it is i cant seem to find it on the pro list
I am new to Listery and this forum but I can report that on my Windows 10 PC Listery finds and opens Control Panel without any difficulty at all ---- so it seems you have a problem with your system. I am not expert enough to suggest what to do, apart perhaps re-installing the app?.
Sorry that Listary can’t search control panel settings at the moment.
I know this is not what you want to hear, but there’s a slightly longer workaround.
Type “Control Panel” in explorer
Drag the control panel icon on the top left of the window to the desktop
Put that control panel shortcut on the desktop in a trusted folder in listary
Type “Control Panel” in listary and it will show the shortcut.
When the traditional control panel launches, you can quickly hit CTRL+F and search quickly.
This is the only way to do this
