Would it be possible to add into Listary the auto-centering on-screen, the Browse For Folder dialog? And/or remembering where the user positioned the dialog the last time, and always re-position that dialog as Listary attaches itself to it?
Reason:
Whenever some app opens that dialog, it’s defaulted to way down low on the screen, and also, when Listary attaches itself to the bottom (where I do like it), Listary overlaps the buttons on that dialog. I always have to manually move the BFF dialog higher up in order to see (and use) everything.
screenshot example (left shot is original position, right shot is after moving it higher up):
https://i.imgur.com/rUuXAr7.png
If Listary could just do some auto-centering (including it’s own height of the toolbar) or record the Top/Left coords of the BFF dialog whenever it’s moved around, then reposition it to those coords when it attaches itself to the BFF dialog, life would be that much greater.
